Hello there,
I'd like to use a own SQL function that I created in HANA Studio and added a computed column to my feature class .The SDE is in a SAP Hana Database obviously.
The SQL function looks like this:
CREATE FUNCTION GET_BEZIRK (IN geom ST_GEOMETRY)
RETURNS
namgem NVARCHAR(100) LANGUAGE SQLSCRIPT AS
BEGIN
DECLARE point ST_GEOMETRY;
point = :geom.ST_CENTROID();
SELECT bezirk.NAMGEM INTO namgem FROM "SCHEMA"."BEZIRK" bezirk WHERE point.ST_INTERSECTS(bezirk.shape) = 1;
END;
My expectation is to calculate the column, when a new feature is added to the feature class. The outcome unfortunately looks like this.
Another way to solve the problem is the usage of attribute rules, but to be honest I'd like to use the Database for the heavy lifting.
Maybe some of you guys encountered something similar or has an idea why the field can't be computed in that fashion. I'm a bit clueless.
