With the EB webapp I created, I would like the webapp to go to a location specified by latitude, longitude coordinates passed through the URL of the webapp. I am unable to find the URL parameters to do this and if this is possible. Thanks!
@USLEOperations Unfortunately, I don't think we've supported that yet. You might consider bringing it to Esri Support for an ENH or post it in the Experience Builder Ideas category for further evaluation. Thanks.
This is such basic functionality - the ability to pass location / scale to a map via a URL. Yes, I know that Ex B does "so much more" than a basic map. But if ESRI isn't going to maintain (or truly replace) WAB (or other, previous options) and tell us that Ex B is so great it needs to be able to do Basic stuff too.
Hi All,
Just a quick update to let you know that the Map widget now supports center parameter that allows you to center a map by desired coordinates. please refer to Center a map for more details. Thanks!
Thank you Shen. Very good.
However I'm having some problems to make it work. If my map is in sub page of ExB it doesn't seem to work. Also, the coordinates aren't working when using simple lat/long wgs84 format. Can I find examples and more documentation about that anywhere other than the link you posted above (which doesn't contain much)? Thanks
@JoabelBarbieri I think there will be a blog about using URL parameters soon. Regarding to the issues you have:
Thanks, Shen, Anything new on this? I noticed that the What's New of ExB June 24 version doesn't add anything new as URL parameters
