Is there a way to see what exactly happened in the background of a modelbuilder workflow? For example, what SQL commands were executed in the geodatabase?
export the model to a script and examine its contents
Thank you for your fast reply. If I export the model, I get the python script, but what if I want to see the SQL-Code because I ArcGIS works with a geodatabase?
Thx in advance!
if sql was used by portions of the model it will show it, otherwise it won't
