Hello,
I am trying to create an attribute rule that will auto populate a GUID field type. I know how to do it with the field calculator but I am unsure of an attribute rule that can do this. I want it so when a new piece of data is put in it populates the GUID field with GUID data without me having to do anything.
Is this possible?
Sorry about that. Try just 'Return guid()' (without the 'digits'). This worked for me (I just tested it).
return guid()
There is a GUID Arcade function that should do the trick.
Data Functions | ArcGIS Arcade | ArcGIS Developer
So I think the below will work if that is the format you are looking for.
return GUID('digits')
That did not seem to work for me. all i had to do was paste the code as is correct? because that gave me an error saying invalid expression.
Thank you @KimberlyGarbade for the response
It gives an error that says Invalid Expression. I do not believe that works for me. was it able to work for you Kim?
@KimberlyGarbade
that was it thank you!
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
