With the Go to XY tool, I have the flash and pan function. I do not the point graphic/mark location function. Is this because of the version I am using -- ArcGIS Pro 2.6?
Hard to tell as it seems they've removed the docs for anything earlier that 2.8.
However, it does say that the point graphic tool only works in 2D. Is your map 3D by chance?
R_
No, my map is in 2D
I'm using ArcGIS Pro 2.9.2 and this capability is available. Per the help doc -
