Hi,I was trying to get the list of points in feature menu of popup. But as shown in below snapshot, feature menu list is showing only 20 list . But there are 58 points there. So how can I display entire 58 points in the feature menu list.
Hi. What browser are you using? This appears to be a bug. When the popup contains more than 20 features, it only loads the first 20, then it (should) paginates queries for the remaining features as you scroll through the list. If you can consistently reproduce, I would report this to technical support so we can get a bug logged and fixed soon.
Also, which API version are you using?
Browser -> chrome .... API version 4.20
yes it's consistently there. If I click on back page initiation and go to 58 item (last) then entire list with 58 items are appearing but after refresh of page same issue as above screenshot.I am using google chrome browser and API version is 4.20
@KristianEkenes if possible can you tell me how can I enable this browse feature widget in my popup, it will show the list. Also is there a way to keep the list view always open.
I'm not able to reproduce this on my side. Perhaps tech support will be able to help you diagnose it...
There isn't a way to do this at the moment, but we can expose a property on the PopupViewModel that would allow you to always have browsing enabled.
FYI, I just logged an issue to expose this feature in a follow up release.
@KristianEkenes ,Thanks, If that property can be enabled, it will be of great help. Also how can I bring this widget "Browsing feature" as you can see in the snapshot I don't have it.
Browsing features is only available for clustering...though it is essentially the same as paging through features in the popup. You do have that capability in the screenshot when you click the "1 of 58". The difference with "browse features" is that a cluster has its own popup and "browse features" gives you access to all features included in the cluster. In this case above, there is no cluster popup, so a "browse features" action isn't necessary.
The fact that the paging isn't working past the first 20 features looks like a bug, so you'll need to provide your repro case to tech support so we can fix it.
@KristianEkenes What are all the things that I, need to provide, If possible please tell me. Also If I provide all those things here in the reply that would be sufficient right?
