While using the Reclassify tool from within Modelbuilder, I tried saving a remap table and it did not create the file. Also, the open remap file does not appear to be working.
Hi James,
Would it be possible for you to provide a screenshot of your model and any additional information about how you set the parameters - I want to try testing it out on my end to see if I get the same behavior you are seeing.
Also, if you reclassify the raster "manually" (that is, outside ModelBuilder, using geoprocessing tools), are you able to save the remap table. If so, does the remap file work as expected?
Hi Megan,
I'll work on getting you that info.
Jim
Megan,
I'm basically recreating the "Mountain Lion Corridors" tutorial using my
own parameters.
Here's a few screenshots I hope will help you out. I noticed in the file
save dialog it says "All Tables" but not types or file extensions are
listed. I tried to add an extension such as .txt to the file name, and it
seems to work. Maybe it just needs a default extension to to make it
"idiot" proof . The same thing happens when I use the Reclassify tool
from outside of Modelbuilder.
Also, what make it a bit confusing is the file save and load dialog boxes
don't update when they are closed and reopened. I learned that I needed to
refresh them manually by clicking the refresh button at the top of the
window.
Hope this helps.
