ArcGIS Pro: How to zoom to xy coordinates navigated by the “go to xy” tool?
In ArcMap, there is “zoom to” tool by which one can navigate to “xy”
I like the XY locator option best, but you can also use Go To XY, then just change your map's scale with the zoom scale selector, the "fixed zoom in/out" buttons, or just using the num pad's + and - keys.
Click the Locate command in the Inquiry group on the Map core tab. In the Locate Pane, enter your coordinates and hit the Enter key. In the results, right click on the XY provider results and select Zoom To. That's one way. In the the Go To XY, click the "hand" icon to pan to the location.
Thank you guys for the help and the two workarounds.
Please, vote:
ArcGIS Pro 2.8.4: Having an option to “zoom in” when working with “go to xy” tool,
