Hi all,I am Anisim and i need to know the steps for Oracle 11g R2 installation (needed for Enterprise Geodatabase).Thank for all,Anisim
You just need to follow the ST_GEOMETRY install instructions. The library isinstalled with the path present in Desktop, so you must alter the library to pointto the location you specified to the listener.In the future, please start a new thread for a new question.- V
EVERY Oracle install contains the minimum requirements for ArcGIS (or can beeasily updated to contain the missing packages). You really need to understandthe underlying database to get your best value out of ArcSDE. Unfortunately,there is no short-cut to learning Oracle -- you just need to do it (or choose a different RDBMS with a less steep learning curve [they're all pretty steep]).As a 24+ year Oracle DBA I am among the least likely on the planet to begiving advice on simple install techniques (I tweak *everything*, and I tweakdifferently at every site, and I doubt I could explain why I did what I did what I did in under a week). There are nearly 5 million hits for a search on "oracle install tutorial", but the first page looks like there's pretty good stuff to behad right there.- V
Oracle installation and configuration is a *huge* topic unto itself. Esri documentationonly covers the ArcGIS-specific bits of Oracle configuration. It's not appropriate (or neccessary) for Esri to dictate how Oracle (or any other enterprise RDBMS) should beadministered; the closest you'll find is the Educational Services classes, but even theystart with RDBMS installed on the machine. The RDBMS vendor is going to be the bestinstructor for best practices in their enironment.- V
