Hi all
I would like to add a 3D-Service which i published to ArcGIS Online in Portal for ArcGIS. Because it is not a public service i need to input the credentials.
If I insert it to a webmap I need to input the credentials every time? Is there a way to store them in Portal for ArcGIS?
Cheers
What version of Portal for ArcGIS are you using? I believe this was a bug at 10.2.2 where it would not prompt you to store credentials for secure services.
Thanks for the fast response. We use 10.5 just installed 4 weeks ago....
Try adding the following service and see if it prompts you to store the credentials:
https://sampleserver6.arcgisonline.com/arcgis/rest/services/SaveTheBay/FeatureServer/0
Username: user1
Password: user1
I need to set the credentials every time i open the map
Is this still necessary with 10.5:
https://community.esri.com/thread/174629
You should receive the following:
Is there a reverse/forward proxy in your configuration? If so, try setting this in the Portal Administrator:
Use a reverse proxy server with Portal for ArcGIS—Portal for ArcGIS (10.5) | ArcGIS Enterprise
Using a forward proxy server with Portal for ArcGIS—Portal for ArcGIS (10.5) | ArcGIS Enterprise
Hi Jake
Thanks again for the response. We are one step further. We configured the forwardproxy with the result to get the bullets to store the credentials.
But set to store the credentials or do not store the credentials and "add item" we get the following error-msg:
"Invalid service credentials A JSONObject text must begin with '{' at character 1 of "
What could cause this error?
Do you receive the same error when you try with the service I provided previously?
I do receive the same error message as Jake in my environment.
It seems to be a problem with the proxy, which is a proxy with authentication.
Even if the service account user of portal is allowed to access the internet via proxy, it does not work correctly.
Hi Stefan
Did you ever find a solution for this? I am trying to view some AGOL layers in Portal and do not want to share them publicly.
Hi Chris
I am facing same issue, do you have a clue?
Lakshmanan
Did anyone solve this problem. I'm having the same issue ....
The error message is extremely confusing and does not provide any guidance as to what the underlying issue is.
To troubleshoot this I had to reproduce this issue with the browser dev tools open and inspect each response of the network calls manually. There I was able to see some errors around proxy authentication issues.
From there we configured our Portal server to go through our proxy server for server side calls, see - Configure your portal to use a forward proxy server—Portal for ArcGIS | Documentation for ArcGIS Enterprise
I also had to work closely with our network infrastructure team to to make sure that the domains of the AGS services we were trying to use were whitelisted on the proxy server too. Hope this helps.
