Hello Y'all.
I booted up my ArcGIS Pro tonight and saw bizarre UI glitches in my ArcGIS Pro panes.
I shut down my computer, and Started it up again only to find that this issue still persisted.
The wonky screenshots are below.
Has anyone encountered this?
Thanks!
-Ian Huerta
After trying everything else (including a clean Win10 re-install), what finally fixed this for me was simply uninstalling Alienware Command Center.
I can confirm that I am also facing the same issue from yesterday.
A couple of drivers (recommended by DELL Update) got updated yesterday, after which I am facing the challenge. It might have caused the issue, I feel.
Edit: These are the drivers updated yesterday
- Alienware Command Center Application - A00 - 894.23 MB - Recommended
- Alienware OC Controls Application - A00 - 86.48 MB - Recommended
Thank You SO Much!
Glad I'm not the only one. I also had some NVIDIA update but I worried my copy of ArcGIS Pro was corrupt,
and thus I uninstalled it.
I hope my professor will know about this.
Thanks for replying!
One of the first things to check if you're experiencing display issues are the graphics card drivers. For other troubleshooting tips see Troubleshooting Performance Issues in ArcGIS Pro
Strange thing is, I think the menu to check for hardware was corrupted as well. (Visually at least.)
I am having the same issues. I thought something was wrong with my computer and I uninstalled and reinstalled, ran a full virus scan, checked all updates on drivers, etc. I tried searching for a dozen different descriptions of the error before I found this, so THANK YOU for describing it in a way that agreed with one of my searches! We are not alone! I started having this issue yesterday as well.
Yeah mine is still down as of 5 min ago.
Please work through Troubleshooting Performance Issues in ArcGIS Pro specifically the Hardware Check section and if still experiencing issues you will need to contact technical support.
Thank you.
Hello. I'm also having this Issue, and it started this week too. All my drivers are updated and my system meet all the requirements to run ArcGIS Pro.
Hey everyone I was able to fix the issue on my end today.
I had to factory reset my Alienware Laptop (M15) and start from scratch, I don't recommend this if you are using a organization's computer unless you get permission. I re-installed windows 10 and ArcGIS Pro 2.6 then updated it to 2.8 and it seems to be fine now.
@KoryKramer thanks for the suggestion on the hardware check that's something I may use in the future.
That did the trick. Cheers!
I also feel so bad. I had mentioned the drivers that I had updated after which the issue started popping up, not realizing I just had to uninstall it from the Control Panel.
So it WAS Alianware Command Center.
I'm gonna have to write an e-mail to them in the future about this issue.
A technician at my school found a workaround by creating a new clean user account.
Thank you Randy M.!
Honestly, many thanks go to @JayantaPoddar for making the original report on the two Alienware programs. Well sleuthed!
That is way easier than mine!!!
Ditto to @RandyMorris. Just uninstalled Alienware Command Center and the issue is fixed now. Just started late last week.
Thank you guys! That did the trick for me! It was driving me crazy have this glitch!
I had the same issue after updating to 2.8. After making sure my hardware and drivers were fine @RandyMorris' solution worked for me. I followed the instructions on the Dell support page: https://www.dell.com/support/kbdoc/en-ca/000178439/how-to-remove-and-reinstall-the-alienware-command-center
Thanks for sharing! Almost two months without using ArcGIS Pro because of the Glitch... until someone else helped me find this post 🙏🏼🙌🏼
Once again, I want to highlight @JayantaPoddar for making the original report on the two Alienware programs. Well sleuthed!
Didn't want to choose between ACC and ArcGIS. Got the following from Esri support:
1) Go to Registry Editor > HKEY Current User tab > Software > Microsoft > Avalon.Graphic2) Right click and create new DWORD (32 bit) Value and named as DisableHWAcceleration3) Right click DisableHWAcceleration > Modify > Change Value Data to 1.1 - Disable Hardware Acceleration0 - Enable Hardware Acceleration4) Reference: Microsoft Documentation:- https://docs.microsoft.com/en-us/dotnet/desktop/wpf/graphics-multimedia/graphics-rendering-registry-settings?view=netframeworkdesktop-4.8#disable-hardware-acceleration-option
Zero issues since, both programs coexisting happily.
