Hello,I have made a simple map that has some points with temperature labels in it. I included a small example here where some points are too close to each other. I would like to move only the labels marked with red arrows. What is the easiest method to accomplish this? Should I convert all labels to annotations or graphics?
If you want to manually adjust labels, you will have to convert them to annotations.
Maybe try your luck with a callout first?
