Hello,
I currently have csv files that contain MinGX, MinGY, MaxGX and MaxGY fields, is there a way to change these field to long/lat coordinates so that I can visualize the file?
Thanks.
A sample row or two?
What is the coordinate system of the csv file? If it is not in decimal degrees, this needs to be know in order to "Project" it to a geographic coordinate system
Thanks for responding. I have attached a screenshot of some rows.
Your csv contains projected coordinates. What projection/coordinate system are they in?
And thanks for responding. Please see the attached screen shot of the csv, I hope this answers your question.
This is what we are referring to...
Coordinate systems, projections, and transformations—ArcGIS Pro | Documentation
where did the data origin from (actual location on Earth)?
how was it recorded
Actual location is City of Dearborn, Michigan. I can't see the coordinates system from looking at the properties.
Thank you.
