Is it possible to have two scale bar widget styles displayed? I want both ruler and number.
You should be able to add multiple scale bars, but not without getting into some custom JS coding.
I think you can modify themes that you use (themes folder) or config.json on root folder if your app is already create. Try to duplicate the part of scalebar widget and modify the position.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
