I know this is something we have been asking for forever, but I do not know if there is a real solution for this yet? Did anyone ever manage to recreate the "One to Many Label" script from VB6? Did ESRI finally give us a real solution to do the labeling? I saw one option of doing it using pivot tables that would require ArcInfo license, but that is a very roundabout solution using a license most people don't have. If anyone knows of a working solution please let me know.If you don't know what I am talking about, basically I am looking to make "callout box" type of labels such as:MW01 DEPTH BENZENE XYLENE 12 34 0.78 18 102 9
import arcpy # variables that need to be customized for your specific data def FindLabel ( [FULL_NAME] ): # input the field name of the parent table's relate field inputValue = [FULL_NAME] # repeat the parent table's relate field queryValue = "'" + inputValue + "'" # add query value delimiters for strings or dates here # define the data source path and fields of the related table featureClass = r'\\agency\agencydfs\Trans\rfairhur\Layers\PARCEL_LINES.gdb\ADDRESS_POINT_Locate_JURUP' relatedFieldName = "FULL_NAME" # the relate field name in the related table that corresponds to the input field valueFieldName = "HOUSE_NUMBER" # desired label value field name in the related table # As long as you want a simple single field stacked label you should not need to change this code whereArgs = [arcpy.AddFieldDelimiters(featureClass, relatedFieldName), queryValue] whereClause = "%s = %s" % tuple(whereArgs) labelList = [] rows = arcpy.da.SearchCursor(featureClass, (relatedFieldName, valueFieldName), whereClause) for row in rows: labelList.append(row[1]) labelList.sort() # uses correct sort order for numbers, dates or strings labelList.insert(0, inputValue) # insert input value as a heading return "\n".join(str(labelvalue) for labelvalue in labelList)
Sorry for the delay, changed the code like this::
Function FindLabel ( [HOLEID] )
RelateFieldOfLayerValues = [HOLEID]
RelateFieldOfLayer = "HOLEID"
RelateFieldOfTable = "HOLEID"
strpTable = "DADO"
iMaxLbl1Sz = 0
iMaxLbl2Sz = 0
iMaxLbl3Sz =0
iMaxLbl4Sz = 0
iSpace = 3
Set gp = CreateObject("esriGeoprocessing.GPDispatch.1")
strWhereClause = chr(34) & RelateFieldOfTable & chr(34) & " = '" & RelateFieldOfLayerValues & "'"
Set prows = gp.searchcursor(strpTable,strWhereClause)
Set prow = prows.next
Do until prow is nothing
strLabel1 = prow.DE
strLabel2 = prow.INTERV
strLabel3 = prow.Fe_pct
strLabel4 = prow.GEO
If (Len(strLabel1) > iMaxLbl1Sz) Then
iMaxLbl1Sz = Len(strLabel1)
End If
If (Len(strLabel2) > iMaxLbl2Sz) Then
iMaxLbl2Sz = Len(strLabel2)
If (Len(strLabel3) > iMaxLbl3Sz) Then
iMaxLbl3Sz = Len(strLabel3)
If (Len(strLabel4) > iMaxLbl4Sz) Then
iMaxLbl4Sz = Len(strLabel4)
Loop
Set prows = Nothing
if iMaxLbl1Sz + iMaxLbl2Sz + iMaxLbl3Sz + iMaxLbl4Sz + iSpace - Len(RelateFieldOfLayerValues) > 0 Then
'FindLabel = FindLabel & "<UND>" & RelateFieldOfLayerValues & "</UND>" & String(14, "_") & vbnewline
FindLabel = FindLabel & "<UND>" & RelateFieldOfLayerValues & "</UND>" & String(iMaxLbl1Sz + iMaxLbl2Sz + iMaxLbl3Sz + iMaxLbl4Sz + iSpace - Len(RelateFieldOfLayerValues), "_") & vbnewline
FindLabel = FindLabel & "<UND>" & "<CLR red='0' green='0' blue='255'>" & "|"& "FROM(m)"& "|"&"INT(m)"& vbtab & "|"&"Fe(%)" &"|"&"LIT"& String(iMaxLbl4Sz - Len("LIT"), "_") & "|"& "</CLR>"& "</UND>"& vbnewline
Else
FindLabel = FindLabel & "<UND>" & RelateFieldOfLayerValues & "</UND>" & vbnewline
FindLabel = FindLabel & "<UND>" & "<CLR red='0' green='0' blue='255'>" & "|"& "FROM(m)"& "|"&"INT(m)"& vbtab & "|"&"Fe(%)" &"|"&"LIT"& "</CLR>"& "</UND>"& vbnewline
k1 = iSpace + (iMaxLbl1Sz - Len(strLabel1))
k2 = iSpace + (iMaxLbl2Sz - Len(strLabel2))
k3 = iSpace + (iMaxLbl3Sz - Len(strLabel3))
k4 = iSpace + (iMaxLbl4Sz - Len(strLabel4)) -3
FindLabel = FindLabel & "|"
FindLabel = FindLabel & strLabel1 & "<CLR red='255' green='255' blue='210'>" & String(k1, ".") & "</CLR>"
FindLabel = FindLabel & strLabel2 & "<CLR red='255' green='255' blue='210'>" & String(k2, ".") & "</CLR>"
FindLabel = FindLabel & strLabel3 & "<CLR red='255' green='255' blue='210'>" & String(k3, ".") & "</CLR>"
FindLabel = FindLabel & "<CLR red='255' green='255' blue='210'>" & String(k4, ".") & "</CLR>" & strLabel4 & "|" &vbnewline
End Function
I changed the font you suggested, but still with different tabs. Masked name for confidentiality reasons.[ATTACH=CONFIG]33889[/ATTACH]
Did you use a uniform width font like Lucidia Console? You could also try Courior, Courier New, Letter Gothic Std, OCR A Std, Orator Std, Prestige Elite Std, and Simplified Arabic Fixed. Only fonts where every letter is the same width will come close to working.Fonts like Arial won't work, because the character widths vary too much. There is no way to control letter spacing of variable width character fonts to make a decent looking table.If the font does not fix the problem I would need to see a screen shot of what you are seeing. If the header row width is longer than your value pairs the spacing algorithm would need to be adjusted slightly to account for the extra width.Anyway, no matter what they probably won't be perfect. If you look carefully at my screen shot the vertical separators do vary slightly, but the variance is not enough to make the table layout fail. Since these labels remain dynamic the fact that they only achieve a reasonable table effect with minor imperfections is a decent trade off over other methods that may achieve perfect tables, but that require the labels to become static.
Perfect, thank you.
Perfect, thank you. One more thing, is presented in table form? with rows and columns perfect? Mine were not with correct alignment.
Here is the code I use to build my labels. X_Y_LINK is a text field. There are no NULL values in any of the data. The related table named CL_INTERSECTIONS_PAIRS was already in my map. PAIR_STNAMES is a text field and INT_SPREAD is a double field in the related table. The inputs I changed to fit my data are shown in red. I did modify the code slightly to handle an error that occurs if the header is longer than the detail value pairs or where there are no related records in the relate table. My previous test of my header line revision did not cover these possibilities. The revised lines that corrected the error are shown in bold green italics. The bold green italic lines did not need customization to fit the input data, they just needed to be added. Function FindLabel ( [X_Y_LINK] ) RelateFieldOfLayerValues = [X_Y_LINK] RelateFieldOfLayer = "X_Y_LINK" RelateFieldOfTable = "X_Y_LINK" strpTable = "CL_INTERSECTIONS_PAIRS" iMaxLbl1Sz = 0 iMaxLbl2Sz = 0 iSpace = 5 Set gp = CreateObject("esriGeoprocessing.GPDispatch.1") strWhereClause = chr(34) & RelateFieldOfTable & chr(34) & " = '" & RelateFieldOfLayerValues & "'" Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.PAIR_STNAMES strLabel2 = prow.INT_SPREAD If (Len(strLabel1) > iMaxLbl1Sz) Then iMaxLbl1Sz = Len(strLabel1) End If If (Len(strLabel2) > iMaxLbl2Sz) Then iMaxLbl2Sz = Len(strLabel2) End If Set prow = prows.next Loop Set prows = Nothing if iMaxLbl1Sz + iMaxLbl2Sz + iSpace - Len(RelateFieldOfLayerValues) > 0 Then FindLabel = FindLabel & "<UND>" & RelateFieldOfLayerValues & "</UND>" & String(iMaxLbl1Sz + iMaxLbl2Sz + iSpace - Len(RelateFieldOfLayerValues), "_") & vbnewline Else FindLabel = FindLabel & "<UND>" & RelateFieldOfLayerValues & "</UND>" & vbnewline End If Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.PAIR_STNAMES strLabel2 = prow.INT_SPREAD k1 = (iMaxLbl1Sz - Len(strLabel1)) + 2 k2 = iSpace + (iMaxLbl2Sz - Len(strLabel2)) - 3 FindLabel = FindLabel & strLabel1 & "<CLR red='255' green='255' blue='255'>" & String(k1, ".") & "</CLR>" FindLabel = FindLabel & "|" FindLabel = FindLabel & "<CLR red='255' green='255' blue='255'>" & String(k2, ".") & "</CLR>" & strLabel2 & vbnewline Set prow = prows.next Loop Set prows = Nothing End Function
Remains the same. I can send you the. "Mdb" for you to check?
You have no basis for thinking the "where" is the problem. The code works when the inputs are correct, otherwise I could not have made the screenshot. The only problems are tied to the inputs you are supplying. Your path is likely the problem. The backslash is an escape character and not being interpreted as a backslash. You must make it a raw string to correct that. strpTable = r"A:\Desktop\New Folder\New Folder\BNDS.mdb\TEOR"You can reference a table that is already in your map without using any path and it will work. So add TEOR to the map and make the path: strpTable = "TEOR"You also did not make the two sets of field pairs identical. That is corrected below where I assumed you wanted ATE and GEO listed as paired values under the HOLEID header.Function FindLabel ( [HOLEID] ) RelateFieldOfLayerValues = [HOLEID] RelateFieldOfLayer = "HOLEID" RelateFieldOfTable = "HOLEID" strpTable = r"A:\Desktop\New Folder\New Folder\BNDS.mdb\TEOR" iMaxLbl1Sz = 10 iMaxLbl2Sz = 0 iSpace = 8 Set gp = CreateObject("esriGeoprocessing.GPDispatch.1") strWhereClause = chr(34) & RelateFieldOfTable & chr(34) & " = '" & RelateFieldOfLayerValues & "'" Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.ATE strLabel2 = prow.GEO If (Len(strLabel1) > iMaxLbl1Sz) Then iMaxLbl1Sz = Len(strLabel1) End If If (Len(strLabel2) > iMaxLbl2Sz) Then iMaxLbl2Sz = Len(strLabel2) End If Set prow = prows.next Loop Set prows = Nothing FindLabel = FindLabel & "<UND>" & RelateFieldOfLayerValues & "</UND>" & String(iMaxLbl1Sz + iMaxLbl2Sz + iSpace - Len(RelateFieldOfLayerValues), "_") & vbnewline Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.ATE strLabel2 = prow.GEO k1 = (iMaxLbl1Sz - Len(strLabel1)) + 2 k2 = iSpace + (iMaxLbl2Sz - Len(strLabel2)) - 3 FindLabel = FindLabel & strLabel1 & "<CLR red='0' green='0' blue='0'>" & String(k1, ".") & "</CLR>" FindLabel = FindLabel & "|" FindLabel = FindLabel & "<CLR red='0' green='0' blue='0'>" & String(k2, ".") & "</CLR>" & strLabel2 & vbnewline Set prow = prows.next Loop Set prows = Nothing End Function
It did not work. Is to write the "where" directly?
The field names for the cursor are not supposed to be surrounded by brackets. (I would have put brackets in my example around the red text if I meant for you to enter a field name within brackets for the lines of code below)Change this: strLabel1 = prow.[HOLEID] strLabel2 = prow.[ATE]to this: strLabel1 = prow.HOLEID strLabel2 = prow.ATEHOLEID should be a text field to work with this where clause and should not have Null values.Function FindLabel ( [HOLEID] ) RelateFieldOfLayerValues = [HOLEID] RelateFieldOfLayer = "HOLEID" RelateFieldOfTable = "HOLEID" strpTable = "A:\Desktop\New Folder\New Folder\BNDS.mdb\TEOR" iMaxLbl1Sz = 10 iMaxLbl2Sz = 0 iSpace = 8 Set gp = CreateObject("esriGeoprocessing.GPDispatch.1") strWhereClause = chr(34) & RelateFieldOfTable & chr(34) & " = '" & RelateFieldOfLayerValues & "'" Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.HOLEID strLabel2 = prow.ATE If (Len(strLabel1) > iMaxLbl1Sz) Then iMaxLbl1Sz = Len(strLabel1) End If If (Len(strLabel2) > iMaxLbl2Sz) Then iMaxLbl2Sz = Len(strLabel2) End If Set prow = prows.next Loop Set prows = Nothing FindLabel = FindLabel & "<UND>" & RelateFieldOfLayerValues & "</UND>" & String(iMaxLbl1Sz + iMaxLbl2Sz + iSpace - Len(RelateFieldOfLayerValues), "_") & vbnewline Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.HOLEID strLabel2 = prow.GEO k1 = (iMaxLbl1Sz - Len(strLabel1)) + 2 k2 = iSpace + (iMaxLbl2Sz - Len(strLabel2)) - 3 FindLabel = FindLabel & strLabel1 & "<CLR red='0' green='0' blue='0'>" & String(k1, ".") & "</CLR>" FindLabel = FindLabel & "|" FindLabel = FindLabel & "<CLR red='0' green='0' blue='0'>" & String(k2, ".") & "</CLR>" & strLabel2 & vbnewline Set prow = prows.next Loop Set prows = Nothing End Function
Function FindLabel ( [HOLEID] ) RelateFieldOfLayerValues = [HOLEID] RelateFieldOfLayer = "HOLEID" RelateFieldOfTable = "HOLEID" strpTable = "A:\Desktop\New Folder\New Folder\BNDS.mdb\TEOR" iMaxLbl1Sz = 10 iMaxLbl2Sz = 0 iSpace = 8 Set gp = CreateObject("esriGeoprocessing.GPDispatch.1") strWhereClause = chr(34) & RelateFieldOfTable & chr(34) & " = '" & RelateFieldOfLayerValues & "'" Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.ATE strLabel2 = prow.GEO If (Len(strLabel1) > iMaxLbl1Sz) Then iMaxLbl1Sz = Len(strLabel1) End If If (Len(strLabel2) > iMaxLbl2Sz) Then iMaxLbl2Sz = Len(strLabel2) End If Set prow = prows.next Loop Set prows = Nothing FindLabel = FindLabel & "<UND>" & RelateFieldOfLayerValues & "</UND>" & String(iMaxLbl1Sz + iMaxLbl2Sz + iSpace - Len(RelateFieldOfLayerValues), "_") & vbnewline Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.ATE strLabel2 = prow.GEO k1 = (iMaxLbl1Sz - Len(strLabel1)) + 2 k2 = iSpace + (iMaxLbl2Sz - Len(strLabel2)) - 3 FindLabel = FindLabel & strLabel1 & "<CLR red='0' green='0' blue='0'>" & String(k1, ".") & "</CLR>" FindLabel = FindLabel & "|" FindLabel = FindLabel & "<CLR red='0' green='0' blue='0'>" & String(k2, ".") & "</CLR>" & strLabel2 & vbnewline Set prow = prows.next Loop Set prows = Nothing End Function
The code assumed the related field was a string field, because single quotes are surrounding the value in the where clause variable. strWhereClause = chr(34) & RelateFieldOfTable & chr(34) & " = '" & RelateFieldOfLayerValues & "'" If the relate field was actually a numeric field the code would have to be changed to remove the single quotes from the line of code that builds the where clause. strWhereClause = chr(34) & RelateFieldOfTable & chr(34) & " = " & RelateFieldOfLayerValuesIf this does not answer your question, please copy the specific lines of code into your message that you are concerned about to better help me understand your question.
How would the "where" in string type primary keys?
Jennifer: Thanks for the code. I have modified it slightly to make it slightly easier to change the inputs of the script that need to be customized for user specific data by adding variables in the top lines of the Function. The field names still have to be modified in the body of the text. The inputs are shown in Red, Bold and Italics similar in your code. I also modified the label style created by the code by eliminating the horizontal line inserted below the table header by using an underline of the header instead to reduce the amount of vertical space needed for each label. As you mentioned, the label font needs to have uniform spaced characters to work correctly. Function FindLabel ( [RelateFieldOfLayer] ) RelateFieldOfLayerValues = [RelateFieldOfLayer] RelateFieldOfLayer = "RelateFieldOfLayer" RelateFieldOfTable = "RelateFieldOfTable" strpTable = "PathToRelateTable" iMaxLbl1Sz = 0 iMaxLbl2Sz = 0 iSpace = 5 Set gp = CreateObject("esriGeoprocessing.GPDispatch.1") strWhereClause = chr(34) & RelateFieldOfTable & chr(34) & " = '" & RelateFieldOfLayerValues & "'" Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.LabelField1 strLabel2 = prow.LabelField2 If (Len(strLabel1) > iMaxLbl1Sz) Then iMaxLbl1Sz = Len(strLabel1) End If If (Len(strLabel2) > iMaxLbl2Sz) Then iMaxLbl2Sz = Len(strLabel2) End If Set prow = prows.next Loop Set prows = Nothing FindLabel = FindLabel & "<UND>" & RelateFieldOfLayerValues & "</UND>" & String(iMaxLbl1Sz + iMaxLbl2Sz + iSpace - Len(RelateFieldOfLayerValues), "_") & vbnewline Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.LabelField1 strLabel2 = prow.LabelField2 k1 = (iMaxLbl1Sz - Len(strLabel1)) + 2 k2 = iSpace + (iMaxLbl2Sz - Len(strLabel2)) - 3 FindLabel = FindLabel & strLabel1 & "<CLR red='255' green='255' blue='255'>" & String(k1, ".") & "</CLR>" FindLabel = FindLabel & "|" FindLabel = FindLabel & "<CLR red='255' green='255' blue='255'>" & String(k2, ".") & "</CLR>" & strLabel2 & vbnewline Set prow = prows.next Loop Set prows = Nothing End Function
Function FindLabel ( [RelateFieldOfLayer] ) iMaxLbl1Sz = 0 iMaxLbl2Sz = 0 iSpace = 5 Set gp = CreateObject("esriGeoprocessing.GPDispatch.1") strWhereClause = chr(34) & "RelateFieldOfTable" & chr(34) & " = '" & [RelateFieldOfLayer] & "'" strpTable = "PathToRelateTable" Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.LabelField1 strLabel2 = prow.LabelField2 If (Len(strLabel1) > iMaxLbl1Sz) Then iMaxLbl1Sz = Len(strLabel1) End If If (Len(strLabel2) > iMaxLbl2Sz) Then iMaxLbl2Sz = Len(strLabel2) End If Set prow = prows.next Loop FindLabel = FindLabel & "<FNT name='Arial' size='6.25'>" & [RelateFieldOfLayer] & "</FNT>" & vbnewline FindLabel = FindLabel & String(iMaxLbl1Sz + iMaxLbl2Sz + iSpace, "_") & vbnewline Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.LabelField1 strLabel2 = prow.LabelField2 k1 = (iMaxLbl1Sz - Len(strLabel1)) + 2 k2 = iSpace + (iMaxLbl2Sz - Len(strLabel2)) - 3 FindLabel = FindLabel & strLabel1 & "<CLR red='255' green='255' blue='255'>" & String(k1, ".") & "</CLR>" FindLabel = FindLabel & "|" FindLabel = FindLabel & "<CLR red='255' green='255' blue='255'>" & String(k2, ".") & "</CLR>" & strLabel2 & vbnewline Set prow = prows.next Loop End Function
Function FindLabel ( [RelateField] ) iMaxLbl1Sz = 0 iMaxLbl2Sz = 0 iSpace = 3 Set gp = CreateObject("esriGeoprocessing.GPDispatch.1") strWhereClause = chr(34) & "RelateFieldinTable" & chr(34) & " = '" & [RelateField] & "'" strpTable = "path to your relate table" Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.Depths strLabel2 = prow.TotalPAHs If (Len(strLabel1) > iMaxLbl1Sz) Then iMaxLbl1Sz = Len(strLabel1) End If If (Len(strLabel2) > iMaxLbl2Sz) Then iMaxLbl2Sz = Len(strLabel2) End If Set prow = prows.next Loop FindLabel = "<UND>" & FindLabel & [RelateField] & "</UND>" & vbnewline Set prows = gp.searchcursor(strpTable,strWhereClause) Set prow = prows.next Do until prow is nothing strLabel1 = prow.Depths strLabel2 = prow.TotalPAHs k = (iMaxLbl1Sz - Len(strLabel1)) + iSpace + (iMaxLbl2Sz - Len(strLabel2)) FindLabel = FindLabel & strLabel1 & String(k, ".") & strLabel2 & vbnewline Set prow = prows.next Loop End Function
Ah, interesting, zooming in did take prevent the crash. Didn't think that would matter since the labels would have to be created anyway. I am still a little hesitant that it might crash the system anytime but it does work.For the sql statement, I just wanted a data filter, which I worked around by putting it in the code with an if statement instead of using a sql clause for row in rows: if row[1] == "CHROMIUM": # data filter finalString = (str(row[1]) + ": " + str(row[2]) + ": " + str(row[3])) # combining the label fields labelList.append(finalString)
import arcpy # variables that need to be customized for your specific data def FindLabel ( [SampleName] ): # input the field name of the parent table's relate field inputValue = [SampleName] # repeat the parent table's relate field # define the data source path and fields of the related table featureClass = r'Chromium_Data' relatedFieldName = "sampleid" # the relate field name in the related table that corresponds to the input field valueFieldName = "param" # desired label value field name in the related table valueFieldName2 = "depth" # second field to label valueFieldName3 = "result" # third field to label # As long as you want a simple single field stacked label you should not need to change this code whereArgs = [arcpy.AddFieldDelimiters(featureClass, relatedFieldName), "'" + inputValue + "'", arcpy.AddFieldDelimiters(featureClass, valueFieldName), "'CHROMIUM'"] whereClause = "%s = %s AND %s = %s" % tuple(whereArgs) labelList = [] rows = arcpy.da.SearchCursor(featureClass, (relatedFieldName, valueFieldName, valueFieldName2, valueFieldName3), whereClause) for row in rows: finalString = (str(row[1]) + " - " + str(row[2]) + " - " + str(row[3])) # combining the label fields del row labelList.append(finalString) del rows labelList.sort() # uses correct sort order for numbers, dates or strings labelList.insert(0, inputValue) # insert input value as a heading return "\n".join(str(labelvalue) for labelvalue in labelList)
Finally got it to work to look more like what I want, although running into a resource problem which is causing ArcMap to crash.This code works, and does what I need it to do to display two fields instead of just the one import arcpy # variables that need to be customized for your specific data def FindLabel ( [SampleName] ): # input the field name of the parent table's relate field inputValue = [SampleName] # repeat the parent table's relate field # define the data source path and fields of the related table featureClass = r'Chromium_Data' relatedFieldName = "sampleid" # the relate field name in the related table that corresponds to the input field valueFieldName = "depth" # desired label value field name in the related table valueFieldName2 = "result" # second field to label # As long as you want a simple single field stacked label you should not need to change this code whereArgs = [arcpy.AddFieldDelimiters(featureClass, relatedFieldName), "'" + inputValue + "'"] whereClause = "%s = %s" % tuple(whereArgs) labelList = [] rows = arcpy.da.SearchCursor(featureClass, (relatedFieldName, valueFieldName, valueFieldName2), whereClause) for row in rows: finalString = (str(row[1]) + ": " + str(row[2])) # combining the label fields labelList.append(finalString) labelList.sort() # uses correct sort order for numbers, dates or strings labelList.insert(0, inputValue) # insert input value as a heading return "\n".join(str(labelvalue) for labelvalue in labelList) This code theoretically works using 3 label fields, the code verification process displays the correct result, but the processing is too much and causes ArcMap to crash. import arcpy # variables that need to be customized for your specific data def FindLabel ( [SampleName] ): # input the field name of the parent table's relate field inputValue = [SampleName] # repeat the parent table's relate field # define the data source path and fields of the related table featureClass = r'Chromium_Data' relatedFieldName = "sampleid" # the relate field name in the related table that corresponds to the input field valueFieldName = "param" # desired label value field name in the related table valueFieldName2 = "depth" # second field to label valueFieldName3 = "result" # third field to label # As long as you want a simple single field stacked label you should not need to change this code whereArgs = [arcpy.AddFieldDelimiters(featureClass, relatedFieldName), "'" + inputValue + "'"] whereClause = "%s = %s" % tuple(whereArgs) labelList = [] rows = arcpy.da.SearchCursor(featureClass, (relatedFieldName, valueFieldName, valueFieldName2, valueFieldName3), whereClause) for row in rows: finalString = (str(row[1]) + " - " + str(row[2]) + " - " + str(row[3])) # combining the label fields labelList.append(finalString) labelList.sort() # uses correct sort order for numbers, dates or strings labelList.insert(0, inputValue) # insert input value as a heading return "\n".join(str(labelvalue) for labelvalue in labelList) It would be nice if ArcMap could handle this by itself, but I could work around it by pre-concatnating my 3 fields into one within the database. Of course editing the database is not an ideal solution, but at least we got a working solution.Side question, do you know if there is a way to run a SQL statement within the code to filter the results, such as only displaying results where "valueFieldName3 = "desiredValue""?
