I get this error message: "Get this error message: "Error: The network dataset properties were not updated. [excetion from HRESULT: 0x80040301]" when using the tutorial data (San Diego Dataset) to create the Network Dataset from ArcGIS Pro.
Hello, everyone. This issue proved to be a bit weird - difficult to reliably reproduce, and some of us could and some of us couldn't. However, we believe we have fixed it. The fix will be in the upcoming ArcGIS Pro 2.9 release. For anyone reading this in the future: If you see this error in Pro 2.9 or higher, please leave a comment here with details about your workflow so we can try to figure out what we missed. Thanks.
Solved: Update data in a network dataset using python - Esri Community
related perhaps
Can you give some further details about your workflow? That error is unexpected, but there's not really enough information here for me to help you figure out what went wrong.
You're probably training to modify the properties of your network dataset.
The error occurs because the network dataset properties cannot be edited while the network dataset layer is in the map. You must remove the layer (network dataset) from the map to proceed with the rest of the tutorial.
I made it all the way to the Build the network dataset section of this tutorial and have gotten the same error "Error: The network dataset properties were not updated. [Exception from HRESULT: 0x80040301]" I don't have the Network dataset layer open on my map either as the tutorial tells you to remove it from the map.
It seems like if you cancel out of properties and go back into the properties and click okay though, the error no longer shows up and it updates the information anyhow. Just a weird error, wondering why it comes up in the first place?
I was able to reproduce the problem reported here. We are investigating.
Question for those of you who have gotten this error: Do you happen to remember if you deleted the network dataset and then recreated it before you saw this problem?
I got this problem right away after the first time I created the network dataset and went into the properties to change it.
I just hit the error and found this post. Your work around of hit cancel then go back to the properties and hit ok worked and the error did not show again.
I had previously created a network dataset with a different name inside the dataset I'm using, deleted it, then created the one I am using now.
Okay, thank you. That's consistent with the behavior we saw when testing. This should be resolved in the 2.9 release.
I had the same result.
I was doing the same tutorial and get the ERROR 030222: The network dataset cannot be created from the given parameters.
I am using Pro 3.0
Hello Lixiaona. This looks like a geoprocessing tool error, so the problem is unrelated to the issue described by the other users in this post. The problem they experienced was related to clicking the OK button on the network dataset properties.
Please describe the parameters you've used in the tool or post a screenshot of the tool dialog. You might also consider making a fresh post in a new topic because this is a separate problem.
Hi, I get this message when trying to copy a Travel Mode in one of the (in-house) network datasets, but not in all. I will tru to troubleshoot it. Pro 3.2.2
If you can share your data and the changes you made to the network dataset properties that reproduce the problem, we can take a look. Alternatively, you can submit a ticket through Esri Support (or through your distributor), and we can look at it that way as well.
thanks @MelindaMorang I am at the distributor and can always create and escalate a case but for this "public" discussion it would be nice to share a result here as well. The network is approx 500 MB's - I can PM you with a link for download. Thanks !
I came across this error after running the "Create a Network Dataset" tool. I am currently using ArcGIS Pro version 3.3.0. The fix I found was to copy the path of the Transportation File GDB from the Catalogue and paste it into the Target Feature Dataset parameter.
I'm using 3.5, and have created my own network dataset for Sacramento, CA. Got this error when I went into the source setting tab.
Thanks for reporting that. Can you share your network dataset with me? You can send me a private message through this platform or e-mail me at mmorang@esri.com. If you need a secure data upload link, I can provide one.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
