i'm using DevExpress 19.1 and arcgis runtime 100.9,
using the dev express docking capability to detach part of the ui to a stand alone view,
the entire app freezes when there is a loaded map inside the view i'm detaching
the main tread freezes with the following call stack :
none of my code exists in the call stack.
any idea?
Adding the entire call stack of main thread -
Main Thread Main Thread WindowsBase.dll!System.Windows.Threading.DispatcherSynchronizationContext.WaitNot Flagged > 30340 1 Main Thread Main Thread WindowsBase.dll!System.Windows.Threading.DispatcherSynchronizationContext.Wait
[Managed to Native Transition]
WindowsBase.dll!System.Windows.Threading.DispatcherSynchronizationContext.Wait(System.IntPtr[] waitHandles, bool waitAll, int millisecondsTimeout)
[Native to Managed Transition]
mscorlib.dll!System.Threading.WaitHandle.InternalWaitOne(System.Runtime.InteropServices.SafeHandle waitableSafeHandle, long millisecondsTimeout, bool hasThreadAffinity, bool exitContext) Line 243
mscorlib.dll!System.Threading.WaitHandle.WaitOne(int millisecondsTimeout, bool exitContext) Line 194
Esri.ArcGISRuntime.WPF.dll!Esri.ArcGISRuntime.Internal.HostedSurfaceElement.CreateHostedElementOnWorkerThread()
Esri.ArcGISRuntime.WPF.dll!Esri.ArcGISRuntime.Internal.HostedSurfaceElement.StartRendering()
Esri.ArcGISRuntime.WPF.dll!Esri.ArcGISRuntime.UI.Controls.GeoView.StartRendering()
Esri.ArcGISRuntime.WPF.dll!Esri.ArcGISRuntime.UI.Controls.GeoView.OnLoadedAsync()
Esri.ArcGISRuntime.WPF.dll!Esri.ArcGISRuntime.UI.Controls.GeoView.MapSurfaceElement_Loaded(object sender, System.Windows.RoutedEventArgs e)
PresentationCore.dll!System.Windows.EventRoute.InvokeHandlersImpl(object source, System.Windows.RoutedEventArgs args, bool reRaised)
PresentationCore.dll!System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject sender, System.Windows.RoutedEventArgs args)
PresentationFramework.dll!System.Windows.BroadcastEventHelper.BroadcastEvent(System.Windows.DependencyObject root, System.Windows.RoutedEvent routedEvent)
PresentationFramework.dll!System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(object root)
PresentationCore.dll!MS.Internal.LoadedOrUnloadedOperation.DoWork()
PresentationCore.dll!System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
PresentationCore.dll!System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
PresentationCore.dll!System.Windows.Media.MediaContext.RenderMessageHandlerCore(object resizedCompositionTarget)
PresentationCore.dll!System.Windows.Media.MediaContext.RenderMessageHandler(object resizedCompositionTarget)
PresentationCore.dll!System.Windows.Interop.HwndTarget.OnResize()
PresentationCore.dll!System.Windows.Interop.HwndTarget.HandleMessage(MS.Internal.Interop.WindowMessage msg, System.IntPtr wparam, System.IntPtr lparam)
PresentationCore.dll!System.Windows.Interop.HwndSource.HwndTargetFilterMessage(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled)
WindowsBase.dll!MS.Win32.HwndWrapper.WndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled)
WindowsBase.dll!MS.Win32.HwndSubclass.DispatcherCallbackOperation(object o)
WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate callback, object args, int numArgs)
WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.TryCatchWhen(object source, System.Delegate callback, object args, int numArgs, System.Delegate catchHandler)
WindowsBase.dll!System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority priority, System.TimeSpan timeout, System.Delegate method, object args, int numArgs)
WindowsBase.dll!MS.Win32.HwndSubclass.SubclassWndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam)
WindowsBase.dll!MS.Win32.HwndSubclass.DefWndProcWrapper(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam)
PresentationFramework.dll!System.Windows.Window.Flush()
PresentationFramework.dll!System.Windows.Window.HwndStyleManager.System.IDisposable.Dispose()
PresentationFramework.dll!System.Windows.Window.CreateSourceWindow(bool duringShow)
PresentationFramework.dll!System.Windows.Window.ShowHelper(object booleanBox)
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.VisualElements.FloatingWindowPresenter.UpdateIsOpenCore(bool isOpen)
DevExpress.Xpf.Core.v19.1.dll!DevExpress.Xpf.Core.BaseFloatingContainer.UpdateContainer(object content)
DevExpress.Xpf.Core.v19.1.dll!DevExpress.Xpf.Core.BaseFloatingContainer..cctor.AnonymousMethod__7_0(System.Windows.DependencyObject d, System.Windows.DependencyPropertyChangedEventArgs e)
WindowsBase.dll!System.Windows.DependencyObject.OnPropertyChanged(System.Windows.DependencyPropertyChangedEventArgs e)
PresentationFramework.dll!System.Windows.FrameworkElement.OnPropertyChanged(System.Windows.DependencyPropertyChangedEventArgs e)
WindowsBase.dll!System.Windows.DependencyObject.NotifyPropertyChange(System.Windows.DependencyPropertyChangedEventArgs args)
WindowsBase.dll!System.Windows.DependencyObject.UpdateEffectiveValue(System.Windows.EntryIndex entryIndex, System.Windows.DependencyProperty dp, System.Windows.PropertyMetadata metadata, System.Windows.EffectiveValueEntry oldEntry, ref System.Windows.EffectiveValueEntry newEntry, bool coerceWithDeferredReference, bool coerceWithCurrentValue, System.Windows.OperationType operationType)
PresentationFramework.dll!System.Windows.StyleHelper.ApplyTemplatedParentValue(System.Windows.DependencyObject container, MS.Internal.FrameworkObject child, int childIndex, ref MS.Utility.FrugalStructList<System.Windows.ChildRecord> childRecordFromChildIndex, System.Windows.DependencyProperty dp, System.Windows.FrameworkElementFactory templateRoot)
PresentationFramework.dll!System.Windows.StyleHelper.InvalidatePropertiesOnTemplateNode(System.Windows.DependencyObject container, MS.Internal.FrameworkObject child, int childIndex, ref MS.Utility.FrugalStructList<System.Windows.ChildRecord> childRecordFromChildIndex, bool isDetach, System.Windows.FrameworkElementFactory templateRoot)
PresentationFramework.dll!System.Windows.FrameworkTemplate.InvalidatePropertiesOnTemplate(System.Windows.DependencyObject container, object currentObject)
PresentationFramework.dll!System.Windows.FrameworkTemplate.HandleBeforeProperties(object createdObject, ref System.Windows.DependencyObject rootObject, System.Windows.DependencyObject container, System.Windows.FrameworkElement feContainer, System.Windows.Markup.INameScope nameScope)
PresentationFramework.dll!System.Windows.FrameworkTemplate.LoadOptimizedTemplateContent.AnonymousMethod__2(object sender, System.Xaml.XamlObjectEventArgs args)
System.Xaml.dll!System.Xaml.XamlObjectWriter.OnBeforeProperties(object value)
System.Xaml.dll!System.Xaml.XamlObjectWriter.Logic_CreateAndAssignToParentStart(MS.Internal.Xaml.Context.ObjectWriterContext ctx)
System.Xaml.dll!System.Xaml.XamlObjectWriter.WriteEndObject()
PresentationFramework.dll!System.Windows.FrameworkTemplate.LoadTemplateXaml(System.Xaml.XamlReader templateReader, System.Xaml.XamlObjectWriter currentWriter)
PresentationFramework.dll!System.Windows.FrameworkTemplate.LoadTemplateXaml(System.Xaml.XamlObjectWriter objectWriter)
PresentationFramework.dll!System.Windows.FrameworkTemplate.LoadOptimizedTemplateContent(System.Windows.DependencyObject container, System.Windows.Markup.IComponentConnector componentConnector, System.Windows.Markup.IStyleConnector styleConnector, System.Collections.Generic.List<System.Windows.DependencyObject> affectedChildren, System.Windows.UncommonField<System.Collections.Hashtable> templatedNonFeChildrenField)
PresentationFramework.dll!System.Windows.FrameworkTemplate.LoadContent(System.Windows.DependencyObject container, System.Collections.Generic.List<System.Windows.DependencyObject> affectedChildren)
PresentationFramework.dll!System.Windows.StyleHelper.ApplyTemplateContent(System.Windows.UncommonField<System.Collections.Specialized.HybridDictionary[]> dataField, System.Windows.DependencyObject container, System.Windows.FrameworkElementFactory templateRoot, int lastChildIndex, System.Collections.Specialized.HybridDictionary childIndexFromChildID, System.Windows.FrameworkTemplate frameworkTemplate)
PresentationFramework.dll!System.Windows.FrameworkTemplate.ApplyTemplateContent(System.Windows.UncommonField<System.Collections.Specialized.HybridDictionary[]> templateDataField, System.Windows.FrameworkElement container)
PresentationFramework.dll!System.Windows.FrameworkElement.ApplyTemplate()
PresentationFramework.dll!System.Windows.FrameworkElement.MeasureCore(System.Windows.Size availableSize)
PresentationCore.dll!System.Windows.UIElement.Measure(System.Windows.Size availableSize)
PresentationFramework.dll!System.Windows.Controls.Grid.MeasureCell(int cell, bool forceInfinityV)
PresentationFramework.dll!System.Windows.Controls.Grid.MeasureCellsGroup(int cellsHead, System.Windows.Size referenceSize, bool ignoreDesiredSizeU, bool forceInfinityV, out bool hasDesiredSizeUChanged)
PresentationFramework.dll!System.Windows.Controls.Grid.MeasureOverride(System.Windows.Size constraint)
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.VisualElements.GroupPanel.MeasureOverride(System.Windows.Size constraint)
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.VisualElements.FloatingItemsPanel.MeasureOverride(System.Windows.Size availableSize)
PresentationCore.dll!System.Windows.ContextLayoutManager.UpdateLayout()
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.DockLayoutManager.Update(bool shouldUpdateLayout)
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.UpdateBatch.Dispose()
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.DockControllerExtensions.Float(DevExpress.Xpf.Docking.IDockController controller, DevExpress.Xpf.Docking.BaseLayoutItem item, System.Windows.Rect floatBounds)
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.Platform.FloatingHelper.GetFloatingView(DevExpress.Xpf.Layout.Core.ILayoutElement element)
DevExpress.Xpf.Layout.v19.1.Core.dll!DevExpress.Xpf.Layout.Core.SupportFloatingListener.GetFloatingView(DevExpress.Xpf.Layout.Core.ILayoutElement element)
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.Platform.LayoutViewClientDraggingListener.InitFloating(DevExpress.Xpf.Layout.Core.ILayoutElement element, System.Windows.Point point)
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.Platform.LayoutViewClientDraggingListener.OnDrop(System.Windows.Point point, DevExpress.Xpf.Layout.Core.ILayoutElement element)
DevExpress.Xpf.Layout.v19.1.Core.dll!DevExpress.Xpf.Layout.Core.Dragging.DragServiceState.DoDrop(DevExpress.Xpf.Layout.Core.IView view, System.Windows.Point point, DevExpress.Xpf.Layout.Core.OperationType type)
DevExpress.Xpf.Layout.v19.1.Core.dll!DevExpress.Xpf.Layout.Core.Dragging.ClientDragServiceStateBase.ProcessMouseUp(DevExpress.Xpf.Layout.Core.IView view, System.Windows.Point point)
DevExpress.Xpf.Layout.v19.1.Core.dll!DevExpress.Xpf.Layout.Core.Dragging.DragService.ProcessMouseCore(DevExpress.Xpf.Layout.Core.IView processor, System.Windows.Point screenPoint, DevExpress.Xpf.Layout.Core.Platform.MouseEventType eventType, DevExpress.Xpf.Layout.Core.Platform.MouseEventArgs e)
DevExpress.Xpf.Layout.v19.1.Core.dll!DevExpress.Xpf.Layout.Core.Dragging.DragService.ProcessMouseOverride(DevExpress.Xpf.Layout.Core.IView view, DevExpress.Xpf.Layout.Core.Platform.MouseEventType eventType, DevExpress.Xpf.Layout.Core.Platform.MouseEventArgs ea)
DevExpress.Xpf.Layout.v19.1.Core.dll!DevExpress.Xpf.Layout.Core.UIService.ProcessMouse(DevExpress.Xpf.Layout.Core.IView view, DevExpress.Xpf.Layout.Core.Platform.MouseEventType eventType, DevExpress.Xpf.Layout.Core.Platform.MouseEventArgs ea)
DevExpress.Xpf.Layout.v19.1.Core.dll!DevExpress.Xpf.Layout.Core.Platform.ViewAdapter.ProcessMouseEvent(DevExpress.Xpf.Layout.Core.IView view, DevExpress.Xpf.Layout.Core.Platform.MouseEventType eventType, DevExpress.Xpf.Layout.Core.Platform.MouseEventArgs ea)
DevExpress.Xpf.Layout.v19.1.Core.dll!DevExpress.Xpf.Layout.Core.Platform.BaseView.OnMouseEvent(DevExpress.Xpf.Layout.Core.Platform.MouseEventType eventType, DevExpress.Xpf.Layout.Core.Platform.MouseEventArgs ea)
DevExpress.Xpf.Docking.v19.1.dll!DevExpress.Xpf.Docking.Platform.MouseEventSubscriber.RootUIElementMouseUp(object sender, System.Windows.Input.MouseButtonEventArgs e)
PresentationCore.dll!System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate handler, object target)
PresentationCore.dll!System.Windows.RoutedEventHandlerInfo.InvokeHandler(object target, System.Windows.RoutedEventArgs routedEventArgs)
PresentationCore.dll!System.Windows.UIElement.RaiseTrustedEvent(System.Windows.RoutedEventArgs args)
PresentationCore.dll!System.Windows.Input.InputManager.ProcessStagingArea()
PresentationCore.dll!System.Windows.Input.InputManager.ProcessInput(System.Windows.Input.InputEventArgs input)
PresentationCore.dll!System.Windows.Input.InputProviderSite.ReportInput(System.Windows.Input.InputReport inputReport)
PresentationCore.dll!System.Windows.Interop.HwndMouseInputProvider.ReportInput(System.IntPtr hwnd, System.Windows.Input.InputMode mode, int timestamp, System.Windows.Input.RawMouseActions actions, int x, int y, int wheel)
PresentationCore.dll!System.Windows.Interop.HwndMouseInputProvider.FilterMessage(System.IntPtr hwnd, MS.Internal.Interop.WindowMessage msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled)
PresentationCore.dll!System.Windows.Interop.HwndSource.InputFilterMessage(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled)
WindowsBase.dll!System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame frame)
PresentationFramework.dll!System.Windows.Application.RunDispatcher(object ignore)
PresentationFramework.dll!System.Windows.Application.RunInternal(System.Windows.Window window)
