HiWhen a user first uses a page of mine, which uses API 2.5, it hangs when initially loading, before it gets as far as the CSS, so all the items are showing unstyled. Event logs showHanging application iexplore.exe, version 7.0.6000.17103, hang module hungapp, version 0.0.0.0, hang address 0x00000000.Killing iexplorer and starting again and it all works fine.Deleting temp internet files causes this to happen a second time. I'm guessing it is some conflict with the downloading of all the API code at once.Any ideas?ACM
Update - I tried the same code, but on my personal domain, and it works fine - which seems to point at some sort issue internal issue. But, 😄 it has enabled me to get permission to "test" IE8 on my PC (8 is as far as we can go until we move off XP) - as not only do I have this issue, but I had another scripting issue that just failed on IE7.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
