I understand from what you're saying that in versions 10.1 and 10.2 there are no arcsde command lines. Is it right?
The ArcGIS 10.2 series of releases (ArcGIS 10.2, 10.2.1, AND 10.2.2) will be the last releases that include the ArcSDE command line tools.
I thought ArcSDE and Geodatabase were complimentary homogeneous concepts, since ArcSDE is a particular type of Geodatabase?
Do you know when the support for 10.0 is going to stop?
No. The 10.2.x family will be the last release to have command-line (and API andapplication server) support for ArcSDE.
ArcSDE is currently accessible as a foundational technology (to both ArcGIS and developers)
Does it mean that there will be no need to install ArcSDE on the server side?
Will desktop (and ArcPy) have direct access to Oracle/PostGIS/... geodatabases?What about the post-install on DB side?
What do you mean by foundational technology?
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
