I'm using the JavaScript API version 4.18. I'm building a popup on a layer that has a GUID field that I want to display. The field does not display weather I use defaultPopupEnabled = true or if I create my own template for the layer. I've found this in the CreatePopupTemplateOptions documentation ("System fields such as Shape_Area and Shape_length, in addition to geometry, blob, raster, guid and xml field types are automatically ignored"): https://developers.arcgis.com/javascript/latest/api-reference/esri-support-popupUtils.html#CreatePopupTemplateOptions
Is there anyway to display a GUID field in a popup?
Hi there,
It is working as expected in all scenarios. Here is a test app that I set up for you.
Hope this helps,
-Undral
Thanks very much for your example. However, the field in the service from your example is actually of type GlobalID and not Guid.
GlobalID (type: esriFieldTypeGlobalID, alias: GlobalID, SQL Type: sqlTypeOther, length: 38, nullable: false, editable: false)
The field that I'm trying to show is of type Guid:
type: esriFieldTypeGUID
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
