I am using the filter widget in web app builder to filter data from the last year.
Is there a way to have this widget automatically turn on when you open the app? I have it set to open automatically but I still have to turn the filter on.
In the settings for the particular filter you want applied, on the Options tab, check the box for "apply this filter when widget is opened"
This is not a solution to the original question, which is the same question that I have. I want to be able to have a filter turn on automatically when the user opens the app itself, not the filter widget. Has there been a solution implemented for that?
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
