I'm migrating over to the es modules approach since it's much cleaner than the loader. However I've run into an issue with FeatureFilter.
For anyone else encountering this, I had to specify the '.js' file extension for it to work. Not sure why.
Do you have a sample project to repro this with? I tried locally and not seeing this issue. I checked against the CDN as well and that works too.
https://codepen.io/odoe/pen/bGgJPRz?editors=0010
Okay thanks. I can't share the code unfortunately so I'll dig a bit deeper. Must be something on my end.
