Is there a way to print the attribute table of a shapefile that is added to the map using the "add data" widget?
I came across the same issue a while ago, and I posted this solution.
https://community.esri.com/t5/web-appbuilder-custom-widgets/export-to-csv-from-a-featurelayer-with-no-url/m-p/846221
Thanks! but How can I include this table in the print widget?
I personally didn't print any AT from the print widget. Just export to the csv and then print it from there (notepad or excel).
Thanks for your help. However, I need to add the whole table to the map and print it
Or
use some of the features as labels to be added to the map. I have a hard time finding anything about how we can label polygones in ESRI web app!!!!
