Can you paste a full traceback?
try: print("Place code here") except arcpy.ExecuteError: Errors = "TRUE" logger.error("An error occurred during geoprocessing:") logger.error(arcpy.GetMessages(2)) except Exception as ErrorDesc: Errors = "TRUE" logger.error("An unknown error occurred:") logger.error(ErrorDesc.message)
try: print("Place code here") except arcpy.ExecuteError: Errors = "TRUE" print("An error occurred during geoprocessing:") print(arcpy.GetMessages(2)) except Exception as ErrorDesc: Errors = "TRUE" print("An unknown error occurred:") print(ErrorDesc.message)
Traceback (most recent call last): File "<pyshell#0>", line 1, in <module> arcpy.CopyFeatures_management(polygon, ShapeFile_prj) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 1943, in CopyFeatures raise eAttributeError: <unprintable AttributeError object>
>>> polygon <Polygon object at 0xf34f550[0x347d9e0]> >>> ShapeFile_prj 'F:\\vector\\Biboohra_Koah\\25cm\\TPE0_330000_8135000_1k_cont.shp' >>>
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
