Hi what a good Webinar.
I think currently it is available with s-57 chart by NOAA? Would it be possible to use other countries or hydrographic offices data to be loaded in ArcGIS?
Hi Mingi,
There are a few options depending on your specific needs.
1. As long as those S-57 datasets aren't encrypted with S-63 you can load them into ArcGIS using ArcGIS Maritime This solution is primarily for production but can be used for many other purposes as well.
2. In ArcMap you have the Esri S-57 Viewer add-on. This allows you to view S-57 datasets in ArcMap. Publishing services is not supported. S-63 encrypted datasets are not supported.
3. If you have S-63 encrypted data or require web services, then you will need to use ArcGIS Maritime Server Extension There is also an additional webinar about the extension.
Please let me know if you have additional questions.
Tom
