I can't figure out what is wrong with this expression. I'm trying to calculate an attribute in a point feature class from an intersecting polygon feature using Attribute Rules. I keep getting the error for "Close parenthesis expected" on line 8 but I have no idea why?
Thanks for your help!
In line 1 it appears to be shown as ORG_IA_SqFt (note the under_scores).
What is "layer.Org IA SqFt"? I'm guessing it's the presence of spaces that is causing the issue. If that's an attribute, try layer['Org IA SqFt'], perhaps.
Thanks @JoeBorgione and @jcarlson for your input. Sometimes the simplest questions lead to the best answers. Putting in underscores worked!
