Hi I have a feature layer that i add through the Add data widget however the time isn't showing in the attribute table. I can see it in the popup however.
Can anyone advise what needs to be done?
Victor,
You will have to edit the jimu/utils.js mo.getDefaultPortalFieldInfo function.
//return {fieldName,label,tooltip,visible,format,stringFieldOption} mo.getDefaultPortalFieldInfo = function(serviceFieldInfo){ //serviceFieldInfo: {name,alias,type,...} var fieldName = serviceFieldInfo.name; var item = { fieldName: fieldName, label: serviceFieldInfo.alias || fieldName, tooltip: '', visible: false, format: null, stringFieldOption: 'textbox' }; //https://developers.arcgis.com/javascript/jsapi/field-amd.html#type var type = serviceFieldInfo.type; switch (type) { case 'esriFieldTypeSmallInteger': case 'esriFieldTypeInteger': item.format = { places: 0, digitSeparator: true }; break; case 'esriFieldTypeSingle': case 'esriFieldTypeDouble': item.format = { places: 2, digitSeparator: true }; break; case 'esriFieldTypeDate': item.format = { dateFormat: "longMonthDayYearLongTime" }; break; } return item; };
Notice I have added LongTime to the dateFormat.
Thanks Robert. Not ideal as I am using build in webappbuilder with OOTB attribute widget 😞 but I don't see anyway around this.
Cheers
Unfortunately I don't see a way around it either.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
