I'm in the process of upgrading our ArcGIS Enterprise. I have already successfully upgraded our Portal for ArcGIS. I have also just successfully installed ArcGIS Server 10.81., and then was prompted to log into ArcGIS Server Manager.
This is where I usually run into errors. I am never able to log into ArcGIS Server Manager at this stage...nothing seems to work.
However, in my install notes from last time I have an entry in there that says I need to first install the ArcGIS Server Web Adaptor before I can log into ArcGIS Server Manager. But I was positive that ESRI Tech Support told me last time that it's actually the other way around...that I needed to demonstrate a connection to ArcGIS Server Manager before the Web Adaptor is installed and configured.
Can someone help me set the record straight here? I have already uninstalled the older version of our web adaptor in preparation to install the new version (as we're not supposed to attempt to install a newer version of the web adaptor over an existing - older - version).
Do I go ahead and install the web adaptor, or continue trying to log into ArcGIS Server Manager?
Thanks
