Anyone know how to make fields in a Feature Layer visible or hidden?Tried using the Field Info object, no luck there...desc = arcpy.Describe("FeatureLayer") field_info = desc.fieldInfo visibleFields = ["ID", "NAME", "Rank", "Count"] for index in xrange(0, field_info.count): fieldName = str(field_info.getfieldname(index)) if fieldName in visibleFields: print "Found Field " + str(fieldName) + " in visibleFields. Setting Visible..." field_info.setvisible(index, "VISIBLE") else: print "Field " + str(fieldName) + " not found in visibleFields. Setting Hidden..." field_info.setvisible(index, "HIDDEN")Tried tossing a RefreshActiveView() onto the end, that didn't help either.
