I am encountering an issue using a custom url to push over attributes from a web map via collector or explorer, and launch Survey123 with those attributes carried over. I am using a feature layer as a non editable layer, but push over the attributes from there. In the apps the layer is not even acknowledged as having a pop-up.
When I check the web map in ArcGIS Online it say "the value entered is not valid", with a yellow warning triangle. However it goes away and the popup will launch Survey123 on the desktop and work from the web map on a either iOS or Android via a browser.
In the apps when it has the problem.
I am trying Explorer Version 18.1.2 on an Ipad Mini with the most current operating system.
I am trying Collector Version 19.2.0 on the same Ipad Mini.
I used Collector Beta on an Android device and same issue, but using "Classic" no problem.
Did I miss something? Is this a Tech Support Issue?
