In the documentation of themes, it says "One app can include more than one theme, but it can only use one theme while running." . Theme—Web AppBuilder for ArcGIS | ArcGIS
1. How do you configure the same app to run with multiple themes with a theme switcher ?
2. When I actually switch themes in WAB I seem to lose all the widget configurations that was previously setup . For example if I had setup 10 layers in the Search widget it just defaults back to Geocoder.
What I would like to do is create the same app with the same configuration but for multiple themes.
Thanks in Advance.
