I was configuring a forward proxy with my Portal 10.5.1 environment and after I submitted the proxy address information, I was no longer able to log into the portal administration URL. As it turns out, there is a known issue with I found after the fact:
Error: Unable to sign in to the Portaladmin API after upgrading to Portal for ArcGIS 10.5.1
No matter what administrator user I'm using, I am unable to login and get the "Invalid Token" or "You are not authorized to use this resource". Is it possible to remove the forward proxy information from the Portal outside of the Portaladmin API?
Sam
