ArcGIS Pro 2.4.2: The version of the Pro is not displayed on the icon created in the desktop
For example, the version of ArcMap is used to appear in the desktop icon. This applies also to the icons of ArcGIS Server! They don’t show the version!
If you use the latest, it isn't relevant
There is for sure an advantage to show the version but is there any when it is hidden?
As a developer, you don't have to change the icon every time a version changes cutting down on unnecessary work
I think that this is the easiest thing developers can do but make much of sense for end users!
The simplest solution is to rename the file yourself. Do not know why ESRI did not put the file version in the name of ArcGIS Pro like every other GIS or Windows application that most of us run. I hope this youtube video helps the community out.
How to rename icon in Start Menu (Windows 10)
https://www.youtube.com/watch?v=dpKEaTrLX6M
The GIS user should not have to do this but it is what it is. 🤷
Here is the before and after for the simple fix. Problem solved.
Přihlaste se, abyste mohli přispívat, sledovat obsah a další. Jste tu noví? Zaregistrujte se zdarma.
