Didn't find a similar idea, hope not a duplicate.
Use Case:
I need to design an application for property management - county is not going to renew their current asset mgmt system. Has a map, but focus is more on the table. Also need to tie in inspections.
Amusingly, this is the second request for a system like this that I got this month.
A template that is designed for asset management / field collection - sort of like a mesh between ArcGIS Dashboards, a map, and the ArcGIS StoryMaps tabbed template.
Imagine an application with a map in a corner, but focus is on the attribute table. Selection on the map filters the table, table selection filters the map, etc. Ability to pull up related tables / inspection reports from field apps, as well as look at any attachments by feature selection as well
- Would be able to handle multiple layers / tables - so selecting the layer from a dropdown brings up the associated map, table, attachments, related data/ reports. etc. and allows you to filter / zoom by selection
- Would allow for editing
- Would allow a summary tab (the dashboard) with customizable widgets
