In ArcMap when you were to do a "merge" between say two line features, easily be able to click on each one and have it flash highlighted so you knew visually which one you wanted to keep.
In ArcPro's "merge" it brings up the merge pane, and lists each feature that is included in the merge and their attributes, but when you click on each feature, it doesn't highlight it at all in the map.
Just would like to click on each feature in the Merge pane and have it flash highlight as it used to in ArcMap. This is unless there is something I'm missing and it's possible to do this in the Merge pane?
