When working with feature services, there may be duplicate features, but with different attributes. Take for example a Survey123 form that reports the shelter's current population. Multiple submissions for the same shelter can be provided throughout the day, but you would only like to display the most recent feature. One way to achieve this is through the top filter parameter that's part of the Query Top Features operation. This can be applied to an ArcGIS Online hosted feature layer view. Below are the steps on how to do this.
1. In ArcGIS Online, navigate to your hosted feature service Item Details and click Create View Layer:
2. Specify a Name, Tags, and Description for the view:
In this example, you can see the Shelters have multiple entries for the same shelter, but with different Count values.
3. Go to the Item Details of the hosted view layer. Scroll down and click View next to the URL:
4. Click on the layer name under Layers
5. Edit the URL and add admin between rest/services:
6. Scroll down to the bottom of the page and click Update Definition
7. Delete all the JSON in the Update Layer Definition dialog box
8. Navigate to https://jsonlint.com/ to help define the JSON object to be passed
9. There are 3 parameters that will be passed in the JSON object:
- orderByFields: the name of the field that contains the time you want to sort. ASC = Ascending, DESC = Descending
- groupByFields: the name of the field to be incorporated in the grouping
- topCount: defines the number of features returned from the top features query and is a numeric value
In this example, I want to show each shelter by the latest edit date, so I will enter the following (note: enter the field names and not the field aliases):
<SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"viewLayerDefinition"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"topFilter"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"orderByFields"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"last_edited_date DESC"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"groupByFields"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"sheltername"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"topCount"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Enter this into JSONLint and validate it is correct. Then paste this into the Update Layer Definition dialog box:
10. Click Update Layer Definition
The hosted view layer will now show only the most recent feature for each shelter:
