Well... who needs an advanced license or excel ... Assume we have an array of the format shown in the Input section. We can determine the counts or sums of unique values in a field, using the following. - sort the array on a field,
- get unique values in that field,
- sum using the values in another field as weights
- rotate if desired
<SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np
a <SPAN class="operator token">=</SPAN> <SPAN class="comment token"># your array goes here</SPAN>
a_s <SPAN class="operator token">=</SPAN> a<SPAN class="punctuation token">[</SPAN>np<SPAN class="punctuation token">.</SPAN>argsort<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> order<SPAN class="operator token">=</SPAN><SPAN class="string token">"Class"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
a_u<SPAN class="punctuation token">,</SPAN> idx <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>unique<SPAN class="punctuation token">(</SPAN>a_s<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Class"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> return_inverse<SPAN class="operator token">=</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN>
bin_cnt <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>bincount<SPAN class="punctuation token">(</SPAN>idx<SPAN class="punctuation token">,</SPAN>weights<SPAN class="operator token">=</SPAN>a_s<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'Count'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
ans <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>a_u<SPAN class="punctuation token">,</SPAN> bin_cnt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> dtype<SPAN class="operator token">=</SPAN><SPAN class="string token">'object'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"a_u\n{}\nidx {}\nanswer\n{}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>a_u<SPAN class="punctuation token">,</SPAN> idx<SPAN class="punctuation token">,</SPAN> ans<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
rot90 <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>rot90<SPAN class="punctuation token">(</SPAN>ans<SPAN class="punctuation token">,</SPAN> k<SPAN class="operator token">=</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
and_flipud <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>flipud<SPAN class="punctuation token">(</SPAN>rot90<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#np.flipud(np.rot90(a,k=1))))</SPAN>
frmt <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"pivot table... rotate 90, flip up/down\n{}"</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>frmt<SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>and_flipud<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The trick is to set the data type to 'object'. You just use FeatureClassToNumPyArray or TableToNumPyArray and their inverses to get to/from array format. Ergo....pivot table should NOT be just for an advanced license  For all-ish combos, you can just add the desired lines to the above <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\nrotated {}\n{}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="number token">90</SPAN><SPAN class="operator token">*</SPAN>i<SPAN class="punctuation token">,</SPAN> np<SPAN class="punctuation token">.</SPAN>rot90<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> k<SPAN class="operator token">=</SPAN>i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
f <SPAN class="operator token">=</SPAN> <SPAN class="string token">"\nrotate by {} and flip up/down\n{}"</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="number token">90</SPAN><SPAN class="operator token">*</SPAN>i<SPAN class="punctuation token">,</SPAN> np<SPAN class="punctuation token">.</SPAN>flipud<SPAN class="punctuation token">(</SPAN>np<SPAN class="punctuation token">.</SPAN>rot90<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> k<SPAN class="operator token">=</SPAN>i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
f <SPAN class="operator token">=</SPAN> <SPAN class="string token">"\nrotate by {} and flip left/right\n{}"</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="number token">90</SPAN><SPAN class="operator token">*</SPAN>i<SPAN class="punctuation token">,</SPAN> np<SPAN class="punctuation token">.</SPAN>fliplr<SPAN class="punctuation token">(</SPAN>np<SPAN class="punctuation token">.</SPAN>rot90<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> k<SPAN class="operator token">=</SPAN>i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> | Input table with the following fields 'ID', 'X', 'Y', 'Class', 'Count' <SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> input array<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'a'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">7.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">9.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'c'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">8.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'b'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'a'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'a'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">5.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'b'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">6</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'a'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">7</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">8.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'b'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">7.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">9.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'c'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">9</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'a'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="comment token"># the results</SPAN>
a_u <SPAN class="comment token"># unique values</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'a'</SPAN> <SPAN class="string token">'b'</SPAN> <SPAN class="string token">'c'</SPAN><SPAN class="punctuation token">]</SPAN>
idx <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN>
answer <SPAN class="comment token"># the sums</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'a'</SPAN> <SPAN class="string token">'b'</SPAN> <SPAN class="string token">'c'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">40.0</SPAN> <SPAN class="number token">6.0</SPAN> <SPAN class="number token">2.0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
pivot table<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> rotate <SPAN class="number token">90</SPAN><SPAN class="punctuation token">,</SPAN> flip up<SPAN class="operator token">/</SPAN>down
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'a'</SPAN> <SPAN class="number token">40.0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'b'</SPAN> <SPAN class="number token">6.0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'c'</SPAN> <SPAN class="number token">2.0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> |
