Toggle your map legend on or off
Some maps display a variety of data, so your readers will need a legend to make sense of what’s what. Other maps, meanwhile, are nice and straightforward, and it can be nice to hide the map legend in these instances to reduce visual clutter.
Turning a legend on our off is the same whether you’re configuring a web map, 3D scene, or an express map. Start by opening the map designer and navigating to the Settings tab of the side panel. There, you’ll see a switch to show or hide the legend; simply toggle it on or off depending on your map needs. Your map will update instantly to reflect this change.
