I am looking at the example and having a hard time trying to figure out how to replace the hospital locations defined in the facilitiesOverlay, with features that I would have in a RestEndpoint. Say my hospitals were in a RestEndPoint....
GraphicsOverlay {
id: facilitiesOverlay<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I think this would have to be manipulated as well?
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">createFacilities</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
featureLayerFishing<SPAN class="punctuation token">.</SPAN>featureTable<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//featureLayerFishing.graphics.forEach(function(graphic) {</SPAN>
<SPAN class="keyword token">var</SPAN> facility <SPAN class="operator token">=</SPAN> ArcGISRuntimeEnvironment<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createObject</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Facility"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>geometry<SPAN class="punctuation token">:</SPAN> featureLayerFishing<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilities<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>facility<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I should be able to place the FeatureLayer in the map as such correct?
I tried to modify the createFacilities function above but did no justice as I am not sure how to approach this...
Any thoughts?
Map {
BasemapStreets {}
initialViewpoint: ViewpointCenter {
Point {
x: -13041154
y: 3858170
spatialReference: SpatialReference { wkid: 3857 }
targetScale: 1e5
FeatureLayer {
ServiceFeatureTable {
url: "https://vvv.vvv.vvv.gov/arcgis/rest/services/Projects/vvv/FeatureServer/2"
onLoadStatusChanged: {
createFacilities();
task.load();
}<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
