so there is something wrong with this dataframe, that it seems i cant see.
SOURCEChangeSHAPE1file_c-0.29{'rings': [[[1788402.41, 13301439.29...2file_c-0.24
{'rings': [[[1788428.41, 13301463.29...5file_c-0.24
{'rings': [[[1788447.41, 13301429.29...When i try to write this to a featureclass
df<SPAN class="punctuation token">.</SPAN>spatial<SPAN class="punctuation token">.</SPAN>to_featureclass<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"C:\tmp\sample.shp"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
I get
IndexError<SPAN class="punctuation token">:</SPAN> only integers<SPAN class="punctuation token">,</SPAN> slices <SPAN class="punctuation token">(</SPAN>`<SPAN class="punctuation token">:</SPAN>`<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> ellipsis <SPAN class="punctuation token">(</SPAN>`<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>`<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> numpy<SPAN class="punctuation token">.</SPAN>newaxis <SPAN class="punctuation token">(</SPAN>`None`<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
What am i missing with this dataframe?
