I have a couple of routines that generate anywhere from 30-40 polygons with approximate 800+ points each. I call each routine from two different ArcGIS Pro SDK Button Add-In Controls as part of my custom ArcGIS Pro Add-In. After each routine I take the Polygons that were created add them to the map using the code below (sorry couldn't figure out how to format the coding correctly). It was working for both buttons consistently until yesterday when only one button would work. Meaning that I would click one button this routine would run and I'd see my polygons on the map and then I'd push the second button and the second time the routine would get stuck on the
bool l_created = l_createFeatures.Execute();
line of code (i.e. Execute() never returned). After trying several different things I decided that maybe the problem was my database so I shutdown ArcGIS and I deleted the DefaultGeodatabase folder for my project. I reran and it started working normally again. Any thoughts on what happened and how I can prevent this from happening again? See anything wrong with the code below? Is there a problem with polygons with that many points? My add-in is in beta release now but would like to know the root of the problem before final release. Thank you.
<SPAN class="comment token">// First obtain the FeatureLayer based on the name of the layer (l_featureClassName)</SPAN>
<SPAN class="keyword token">await</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>Tasks<SPAN class="punctuation token">.</SPAN>QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> l_mapLayers <SPAN class="operator token">=</SPAN> l_mapView<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetLayersAsFlattenedList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>OfType<SPAN class="operator token"><</SPAN>FeatureLayer<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">foreach</SPAN> <SPAN class="punctuation token">(</SPAN>FeatureLayer l_featureClassLayer <SPAN class="keyword token">in</SPAN> l_mapLayers<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>l_featureClassLayer<SPAN class="punctuation token">.</SPAN>Name <SPAN class="operator token">==</SPAN> l_featureClassName<SPAN class="punctuation token">)</SPAN>
l_featureLayer <SPAN class="operator token">=</SPAN> l_featureClassLayer<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Second Set the Opacity for the Polygons so I can overlapping Polygons</SPAN>
<SPAN class="comment token">//Create polygon outline.</SPAN>
CIMStroke l_outline <SPAN class="operator token">=</SPAN> SymbolFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ConstructStroke</SPAN><SPAN class="punctuation token">(</SPAN>
ColorFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN>BlackRGB<SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">1.0</SPAN><SPAN class="punctuation token">,</SPAN>
SimpleLineStyle<SPAN class="punctuation token">.</SPAN>Solid<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Create polygon fill with outline.</SPAN>
CIMPolygonSymbol l_fillWithOutline <SPAN class="operator token">=</SPAN> SymbolFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ConstructPolygonSymbol</SPAN><SPAN class="punctuation token">(</SPAN>
ColorFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateRGBColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
SimpleFillStyle<SPAN class="punctuation token">.</SPAN>Solid<SPAN class="punctuation token">,</SPAN>
l_outline<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Get layer's current renderer.</SPAN>
CIMSimpleRenderer l_renderer <SPAN class="operator token">=</SPAN> l_featureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> CIMSimpleRenderer<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Update current renderer's symbol.</SPAN>
l_renderer<SPAN class="punctuation token">.</SPAN>Symbol <SPAN class="operator token">=</SPAN> l_fillWithOutline<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MakeSymbolReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Update layer's renderer.</SPAN>
l_featureLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetRenderer</SPAN><SPAN class="punctuation token">(</SPAN>l_renderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Third Perform EditOperation to add polygons to layer</SPAN>
<SPAN class="keyword token">var</SPAN> l_createFeatures <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">EditOperation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
l_createFeatures<SPAN class="punctuation token">.</SPAN>CancelMessage <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Operation Cancelled"</SPAN><SPAN class="punctuation token">;</SPAN>
l_createFeatures<SPAN class="punctuation token">.</SPAN>ErrorMessage <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Error creating polygon"</SPAN><SPAN class="punctuation token">;</SPAN>
l_createFeatures<SPAN class="punctuation token">.</SPAN>ShowProgressor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// l_arcGISPolygons is List<Polygon></SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">int</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> l_arcGISResults<SPAN class="punctuation token">.</SPAN>Count<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN>
l_createFeatures<SPAN class="punctuation token">.</SPAN>Name <SPAN class="operator token">=</SPAN> $<SPAN class="string token">"Create Result Polygon #{i}"</SPAN><SPAN class="punctuation token">;</SPAN>
l_createFeatures<SPAN class="punctuation token">.</SPAN>ProgressMessage <SPAN class="operator token">=</SPAN> $<SPAN class="string token">"Adding Result Polygon #{i} to the Map....."</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Create a feature with a polygon.</SPAN>
l_createFeatures<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Create</SPAN><SPAN class="punctuation token">(</SPAN>l_featureLayer<SPAN class="punctuation token">,</SPAN> l_arcGISResults<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Execute the operation. Must be called within QueuedTask.Run.</SPAN>
<SPAN class="keyword token">bool</SPAN> l_created <SPAN class="operator token">=</SPAN> l_createFeatures<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Execute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Finally Save Edits to Layer</SPAN>
<SPAN class="keyword token">await</SPAN> Project<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SaveEditsAsync</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
