Robert Scheitlin, GISP
Ok I changed the code where every instance was esearch and made it cfssearch. I have a widget folder called 'cfsSearch)
Issue 1: I get an error when I try to open the widget after I have made it button 1.
Issue 2: When I add the widget a different button position it works.
Issue 3:
I typed in over 500 Radio codes in the predefined option for the Radio Code field and the Final Radio Code field has the same values. I went to the config.json and copied the values to the Final Radio Code values and saved. When I then tried testing it it did not work. It seems like my biggest problem is finding the cfsSearch widget folder. Something is not getting read, do you have any ideas on how to make it find the widget folder and add my modifications to the widget?
