I've built a widget, in the Guide they tell to use the config.json file located in the widget folder (widgets/MyWidget/config.json)
But in my app, the config informations seems to be read from configs/MyWidget/config_MyWidget.json.
When i use the builder with my new widget and set diferents properties in the settings panel and then export the app, the modification are write in configs/MyWidget/config_MyWidget.json and not in widgets/MyWidget/config.json.
I'm a little bit confused, witch file should i use?
thanks!
