I had a Web Map that had a custom visibility range set. The map would first present with a topographic map, and then when the user zoomed in, this map would change to satellite. I changed the default extent of the Web Map, and now when I zoom all the way out in the native app (iOS) the topographic map no longer displays like it used to. It was based on the original Map Viewer Template of App Studio. All I did to the Web Map was changed the default extent, so I am unsure why this would affect the scale dependent visibility ranges. Are you able to suggest why this may be occurring, and how it might be solved?
