Have a tooltip that works well. Just having some trouble to effectively change the text color. Code can be found below
<SPAN class="comment token">// create node for the tooltip</SPAN>
<SPAN class="keyword token">var</SPAN> tip <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Click on problem location"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> tooltip <SPAN class="operator token">=</SPAN> dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"class"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"tooltip"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"innerHTML"</SPAN><SPAN class="punctuation token">:</SPAN> tip <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN>container<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">style</SPAN><SPAN class="punctuation token">(</SPAN>tooltip<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"position"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"fixed"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// update the tooltip as
