Please can somebody help!! I have a huge amount of Ordnance Survey MasterMap Topo data which needs converting to DWG. When I try and run the calculation for a large area (Sheffield District), the calculation is too large and crashes. I therefore break this down by 1km map tiles to make the calculation smaller (use intersect and then split by feature). I then convert these to DWG using a purpose built batch tool in model builder - Does anybody know how to batch process shp. to .dwg files? thanks to Robert Scheitlin, GISP.
The problem is, this only works for one geometry type; so one file for line, polygon and points. Is there a way to batch these together?
