I have a couple of questions for those who have experience with exporting any map whether they be simple or complex maps..
I have a Abode Acrobat Pro DC version 2017.012.20093 installed on my computer.
it is about Reduce File Size or PDF Optimizer that I want to know about.
When you have that program installed on your computer AND when you have a map that was exported from ArcMap to PDF .
Do you usually use Reduce File Size or PDF Optimizer to reduce the file size because the PDF you exported are mega file size and are impossible to email to someone.
If that is the case, do you re-do again a couple of times to get under 10 MB ?
What about the quality of the PDF when you reduce the file size ?
What does it effect on the PDF reduce when you print them to the plotter ?
