I'm receiving the following error when attempting to clone items:
Traceback <SPAN class="punctuation token">(</SPAN>most recent call last<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
File <SPAN class="string token">"<ipython-input-92-d5f15aa1088b>"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN>
gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>clone_items<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'4ef'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'5ef'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
File <SPAN class="string token">"/Users/cour7816/anaconda3/lib/python3.6/site-packages/arcgis/gis/__init__.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">2483</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> clone_items
clone<SPAN class="punctuation token">.</SPAN>_get_item_definitions<SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> item_definitions<SPAN class="punctuation token">)</SPAN>
File <SPAN class="string token">"/Users/cour7816/anaconda3/lib/python3.6/site-packages/arcgis/_impl/common/_clone.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">1556</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> _get_item_definitions
source <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>_gis
AttributeError<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'str'</SPAN> object has no attribute <SPAN class="string token">'_gis'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This is my simple code:
<SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>gis <SPAN class="keyword token">import</SPAN> GIS
<SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>gis <SPAN class="keyword token">import</SPAN> ContentManager <SPAN class="keyword token">as</SPAN> content
gis <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fwww.arcgis.com" target="_blank">https://www.arcgis.com</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>clone_items<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'4ef'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'5ef'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
(Where 4ef and 5ef are my full item ids)
Am I doing something wrong here? Thanks!
