This might sound like a rather silly question but I'm new to building LRS networks. And this is driving me nuts!
When you create an LRS network the process creates a feature class for you with only three fields. You can change the name of the fields but cannot add any fields until your done creating the network feature. My issue is that the SHAPE_Length field ends up being in the middle of the table rather than at the end once you add the new fields. I want the SHAPE_Length field to be at the end like it normally is. How do I get it there? This is not your normal type of feature class. See step 9 in the below link:
Creating an LRS Network—Roads and Highways Desktop | ArcGIS Desktop
In my quandry I imported a feature class with all off the features and fields I wanted into the geodatabase with the LRS ( this feature was used to load the routes), renamed the the feature class that the process described above created, and named my imported the name of the LRS network feature class. That seems to work but it still scares me...is this how it's done?
Ana
