I've been trying to edit a model (which I inherited) that keeps failing on the Translate Events from LRM to LRM. The message says that the XY tolerance is different between the source and target files. The problem appears to me that the source file is a shapefile and the target file is a feature class; the source shapefile is created by the Identity tool which uses a temporary folder on the C:\drive to store the shapefile and then goes through a series of geoprocessing steps before being entered into the LRM to LRM tool with the feature class.
I tried changing the output location of the source file to be the same geodatabase as the target file in the Identity tool step but then the tool fails to create an output in the geodatabase.
The weird thing is that there's another very similar model which works fine but I cannot find what the difference between them is other than the inputs and outputs. I'm a novice model maker so it's quite possible that I'm missing some fundamentals of model building here.
I have attached a copy of both models for your review; the one that fails is called " Recreate GP_MetroPlanningArea" and the one that works is called "Recreate GP Municipality". Also, attached, are screen shots of the error messages I have described above. The database I use for the original two files (i.e. "BM Metro Planning Areas" and "StatewideRoutes") is way to large to attach here.
Ana
